Hang Wired
Old Apr 21, 2013 | 08:39 PM
crimeguy7's Avatar
crimeguy7
Default Hang Wired
I've done some research on the forums. I'm going to install the stage 2 double shot system on my street glide. Has anyone experienced any problems during the install? Anything tips I should know?
Old Apr 21, 2013 | 08:42 PM
UltraWalt's Avatar
UltraWalt
I'm assuming you meant Hawg Wiredand as I understand the redirections are straight forward.
Old Apr 21, 2013 | 08:45 PM
crimeguy7's Avatar
crimeguy7
Default Hawg wired
Yes, hawg wired. Stupid auto correct on the iPad.
Old Apr 23, 2013 | 05:34 PM
UltraNutZ's Avatar
UltraNutZ
what I never did understand about hawg-wired kits is why sell an amp that's stable at 2 ohms yet provide speakers in a kit that are 4 ohm.. makes no sense to me.
Old Apr 23, 2013 | 08:28 PM
The Q's Avatar
The Q
A coworker of mine, who use to do car audio told me 4ohm is "clean" sound and 2ohm is "dirty" sound. He did a better job explaining it than just that, but he said you get cleaner sound from 4ohm systems. I don't know enough about it to debate it one way or the other.
Personally, having spent the money on a Hawg Wired system I'll never do it again. In my opinion, not bad mouthing Hawg Wired, but for the money you can put together a killer system of your own and still have money left over.
Found this explanation on the Polk Audio Forum:
""Oh give me a Ohm where my woofers can roam".... I know, I know, don't quit my day job!!
With a low impedance or resistance of 2 Ohms connected to the amplifier, this will allow for more voltage and current to passed through the load. This will allow for a increase in power rating but at the cost of sound quality. The damping factor of the amplifier is usually cut in half. This is the ratio of the internal output impedance of the amplifier to the load presented to the amplifier. ( Woofers, drivers, etc. ) With low impedance loads this figure is reduced and with higher loads this figure increases. From a sonic standpoint you will find that when the amplifier is presented with a higher impedance of 4 Ohms, the bass definition, detail and extension is usually much better. Current consumption from the vehicle's charging system is also greatly reduced. With low impedance loads the bass kind of takes on a "hard sounding" characteristic that seems to lacks definition and detail. But judge for yourself to see what you prefer. Plus there maybe thermal issues to contend with depending on the amplifiers design and total heat sink area. This can be stressful for the output transistors also. My recommendation for what it is worth... If your goal is sound quality then present the amplifier with a 4 Ohm load and enjoy the music!!"
Last edited by The Q; Apr 23, 2013 at 08:49 PM. Reason: Added info from Polk Audio Forum
Old Apr 23, 2013 | 10:37 PM
rbferg's Avatar
rbferg
I'll second that! Their stuff is great quality but really pricey. Having said that, the kits are very easy to install and you should have no problems.
Teufelhunden
Audio Systems
Apr 28, 2020 02:28 PM
nevera7
Audio Systems
Apr 9, 2017 02:46 AM
CallMeJus
Audio Systems
13
Mar 22, 2016 06:52 PM
Liquidoxygen
Audio Systems
Mar 28, 2015 03:27 PM
jamess71
Audio Systems
Jun 27, 2014 10:28 AM
