ARC Audio MPAK 6 installed (it sucks)
Get a Service Manual...and do exactly what you are doing by getting help on these forums and HAVE FUN!!!
Ratrod, I sure do appreciate the offer and may end up pinging you Saturday if thing go south! Your a great dude for making the offer. Thanks!
As for the Sensitivity of those speakers. I'm hopeful you can adjust the gain to get some oomph out of them, but 86 dB seems pretty poor compared to others.
To compare to the current UN pick... Polk MM651's - they spec at 94 dB.
Real world of course may vary a bit, and i'm unsure if that is at 1w1m or 2.83v.
How that relates to "loudness" (a poor indication of SQ really) is aparent when you look at how many w needed to hit "x" SPL:
speaker sens. (1w/1M) listener distance desired SPL amp. headroom required power
104db 15' (4.6M) 90db 15db 27 watts
101db 15' (4.6M) 90db 15db 53 watts
98db 15' (4.6M) 90db 15db 106 watts
95db 15' (4.6M) 90db 15db 212 watts
92db 15' (4.6M) 90db 15db 422 watts
89db 15' (4.6M) 90db 15db 842 watts
86db 15' (4.6M) 90db 15db 1681 watts
83db 15' (4.6M) 90db 15db 3354 watts
80db 15' (4.6M) 90db 15db 6691 watts
77db 15' (4.6M) 90db 15db 13,351 watts
So after you adjust your gains, if still unhappy w/ them it may be worth looking at a different speaker. Hopefully you won't need to do so, but if you do - the above hopefully shows how much less power you need w/ an efficient speaker.
Anyway - food for thought and hopefully moot once you setup your amp correctly!
HTH and GL!
Last edited by sl33py; May 7, 2013 at 01:17 PM. Reason: trying to fix formatting of table.
Gonna give it a try this weekend. I will report back my findings.
Thanks everyone for the help.
2 things wrong with this statement.
- Dealers don't have "audio techs". Probably some kid who washes bikes put this in for you
- you expected a dealer service department to do something right?
I hope the OP gets his system figured out .
Here are the current settings on the amp:
BX2 is set to ON
BX2 freq seems to be set at half way. I did play with this a little and the bass response change is minimal
The gains are set to about 3/4 of max. I turned the stereo up to 3/4 and adjusted these to what seemed about right (whatever that means to the pros lol)
The crossover does absolutly nothing when turned either way.
The tech did wrap the speakers in polyfil but just 1 layer. I doubt this is doing anything.
It appears that the speakers are wired directly into the amp (like they should be) but no bridging is apparent ( not sure if this right?)
A few pics, but not sure these will help. If anyone has any ideas I would love to hear them.
What is this box that was on top of the amp?
I hope I am not expecting too much from this system.......seems the boom amp/speaker setup was much clearer and louder.
Sorry the pics are upside down. I'm trying to fix that now.
Appreciate the help as always.
Pic1 - yeah this amount of polyfil ain't helping anything. Those speakers need to be wrapped up to look like a gigantic white cotton ball.
Pic2 - here's what I would do. The gains on the amp need to go all the way to min which on most amps is a counterclockwise rotation til it stops. Set your BX to off position. Turn bass and treble on radio to flat positions (if stock radio then that would be the middle bars of each option). Drop in a good high-fidelity CD like Van Halen. Turn volume on radio up until you hear distortion, then turn it down a little. Now turn your left and right gains up equally until you hear distortion again and then turn it back down a little.
the reason you're not hearing any difference with the crossover is because the switch right above the crossover is set to full which disables the crossover. I'd leave it like this.
I'm not sure what that box is but do you have an iPod, XM, or CB option on the bike?
