System upgrade
Old May 20, 2013 | 06:16 AM
vtdiesel's Avatar
vtdiesel
Default System upgrade
I posted a thread last week but can't find it. Need some input from the audio gurus. 13 SG, using the stock head but I want to upgrade the fairing speakers as well as install speakers in the lowers plus an amp. Don't want to spend a fortune either. Thanks
Old May 20, 2013 | 01:15 PM
sl33py's Avatar
sl33py
Here you go:
https://www.hdforums.com/forum/audio...i-install.html
(search - advanced, by user, in audio forum).
You had one response from the guru UN:
Originally Posted by UltraNutZ
Polk MM651 in fairings and lowers
SS PN4.520D to drive both pair
check out the 2nd from the bottom 2012 FLHX in the Step by Step sticky at the top of the forum. Same setup just speakers in different locations.
what does a "fortune" = for you. What's your budget?
A good a amp can be 100-500.
Speakers 60-250.
Adapter rings 30-40
amp wiring kit - 30.
Misc - connectors, polyfill, etc. - 10-20?
Tools - depends what you have already.
MM651's MM651's
are ~$125-140, you can get the lower power
DB651's DB651's
ones for ~$55-70 (both roughly depending on tax + s/h).
Not as budget friendly (pricing similar to J&M), but worth looking at for comparison - Biketronics Titan II's. 6.5" and 7.1" - new 7.1's same price as 6.5's right now on promo @ $249 (plus s/h).
Amps -
RF PBR300x2 RF PBR300x2
($140'ish),
Soundstream PN4.520D Soundstream PN4.520D
(4ch - $140ish - Known FM issues possible), http://www.sonicelectronix.com/item_68787_Precision-Power-i350.2.html ($120'ish)(same internals as SS nano - also same possible FM interference).
so many options it's dizzying. Keep digging and reading and you'll find a good combo that works for you!
Let us know what you go with and Good luck!
Old May 20, 2013 | 01:24 PM
sl33py's Avatar
sl33py
Sorry - see you are looking to add lower's speakers. Disregard the 2ch amps with those MM651's.
MM651's are 2.7 ohm speakers and the amp will clip below 2 ohms (would be 1.35 ohm load in parallel).
Unless you go to 4 ohm speakers, in parallel would be 2ohm load. DB651's are 4 ohm. and the Biketronics as well. There's a bit of cost difference... hehehe.
just wanted to make sure you didn't get a 2ch and those MM651's! need a 4ch for that setup like UN suggested. Hope the reasoning why makes sense to you? (2.7 ohm in parallel = 1.35 ohm load on an amp that can'd do below 2 ohm load).
GL!
WoodButcher66
Audio Systems
Feb 13, 2019 08:04 AM
trailrider
Audio Systems
Jul 25, 2018 06:37 PM
langwilliams
Audio Systems
11
Jun 20, 2018 06:08 AM
atretes1
Audio Systems
Aug 22, 2013 09:07 AM
mastery
Jan 12, 2009 06:50 AM
