polk 651's
Old May 21, 2013 | 08:15 PM
Moxy's Avatar
Moxy
Default polk 651's
are the standard depth 651s a good fit, I see they offer a shallow depth version.
any input appreciated.
Thanks
Moxy
Old May 21, 2013 | 09:38 PM
rbferg's Avatar
rbferg
I don't know what you mean by "shallow depth version" but these are the Polk MM's everyone's using and they fit perfect. You'll need 6.5" speaker adapters as well.
http://www.sonicelectronix.com/item_...FYLm7AodqSYA1w
Old May 21, 2013 | 09:43 PM
blue66's Avatar
blue66
No need for the shallow version. They also reduce bass output by design.
Old May 22, 2013 | 12:32 AM
Sire2Twins's Avatar
Sire2Twins
There is a slim version, but I think they have permanently attached grills, so won't work in the fairing, which is why nobody uses them. I'm definitely not the expert though. The MM651's fit fine, including with the adapters and polyfil, as I have them in mine.
Old May 22, 2013 | 06:28 AM
UltraNutZ's Avatar
UltraNutZ
there are only 2 versions of the MM651 speakers. The MM651 and the MM651-UM. There is no difference in mounting parameters between the two with the only difference being the UM version is the grills do not come off the speaker so you do not want these.
Are you maybe referring to the DB or DXi series speakers? Both of those have S (slim) versions but they are also a different speaker altogether.
Really it depends on what amp you're going with as to which speakers you should use.
Old May 22, 2013 | 04:10 PM
Moxy's Avatar
Moxy
Thanks for the info, amp is the ss 4.520D four channel picasso
Old May 22, 2013 | 06:24 PM
UltraNutZ's Avatar
UltraNutZ
then I'd go the route of the MM651 speakers.
Old May 22, 2013 | 11:07 PM
rellortnoc's Avatar
rellortnoc
Default Polk Speakers
I put Polk Audio 6 1/2 inch speakers in my Limited. I put the standard ones in the fairing and the shallow ones in the pods on the tour pack. Neither had the grill attached. Grills for both were included, but separate. I did have the rear ones bounce out of the pods on a day ride. Almost lost one of them. The little rubber nuts for the OEM speakers are not robust enough for the heavier 6 1/2s. I used captive nuts I obtained from Home Depot. They did not fit right, so I had to bend them a little, but they hold very well.
Old May 23, 2013 | 06:37 AM
UltraNutZ's Avatar
UltraNutZ
if you put shallow mount Polks in your rear pods, you put the wrong ones in there unless you're running an amplifier. The stock head unit is designed to run 2 ohm speakers and without an amp you should replace the speakers with 2 ohm speakers. The Polk MM series are 2 ohm, all the rest of them are 4 ohm speakers.
Old May 23, 2013 | 09:40 PM
Stucustom's Avatar
Stucustom
Can you use the mm series polks with a Sony HU and the SS PN4.520 amp?
