Gain settings
Old May 30, 2013 | 10:03 PM
The Dude's Avatar
The Dude
Default Gain settings
I set ny system up using the dmm method posted in the stickies. Ss 520 and 4 Polk mm651.
After i set my gain adjustment, I dabbed a small bit of silcone on the ***** to keep them from vibrating out of adjustment. Is the vibration any kind of a problem with these settings? it didnt take much **** rotation to make the ac voltage jump.i also had a little differance in voltage betqen left and right. I went ahead and checked them both and made sure my calculated setting was the higher of the two outputs.
Old May 31, 2013 | 06:49 AM
UltraNutZ's Avatar
UltraNutZ
yes sir most of the time you'll notice that slight variance between left and right channels and that's usually due to either a bad test tone track or some inequalities with the source pickup. Nothing to worry about there as long as it's not a significant amount of difference.
As for the silicone, I've never had one vibrate out of adjustment.
Chris Sigo
Shovelhead
Oct 9, 2018 07:51 PM
Tileman2692
Sep 18, 2018 07:18 AM
glsec507
Jun 4, 2018 04:10 PM
bzmannn
Audio Systems
Apr 10, 2018 12:05 PM
Strait
Audio Systems
Apr 14, 2013 06:01 AM
