Speaker question
Old Jun 22, 2013 | 12:26 PM
quigley's Avatar
quigley
Default Speaker question
I know absolutely nothing about audio so please bear with me. I have 2 Kenwood speakers, KEN-KFCX693. Would the ROCKFORD FOSGATE PBR300X2 amp, be a good fit for these speakers?
Thank You
Old Jun 22, 2013 | 01:48 PM
sl33py's Avatar
sl33py
Those (obviously) are 6x9's - what lids are you going to use?
Specs:
3 ohm (good)
89dB sensitivity (not great but not horrible - will need more power (RMS) to push them)
Freq range 50-25k (not a ton of bass/low end)
If you got 'em and have lids for them - yes the 300x2 would work great for them. If you are doing a saddlebag amp i think seperation of the amp from the HU may negate some of the FM issues - the SS 350D may give you more power w/o FM issue (not 100% positive on that...).
HTH - GL!
Old Jun 22, 2013 | 01:57 PM
rbferg's Avatar
rbferg
The RF doesn't have the FM issues like the SS and other class D amps do.
Old Jun 22, 2013 | 02:06 PM
quigley's Avatar
quigley
Thank you for the info. The speakers are actually mounted in a aftermarket fairing. Thanks again.
Old Jun 22, 2013 | 04:33 PM
acchd's Avatar
acchd
Sounds like u might have Dragonfly. Here's one I did over 4.5 yrs ago using Arc amp. BTW I am still using same amp!
https://www.hdforums.com/forum/membe...dragonfly.html
Old Jun 23, 2013 | 08:13 AM
UltraNutZ's Avatar
UltraNutZ
The PBR 300x2 will definitely drive those 6x9s very well. If you want a better matched speaker to the amp then later on you can replace the Kenwoods with the Polk MM691.
Stang951
Audio Systems
Aug 28, 2016 09:26 PM
ridedaddy
Audio Systems
Oct 18, 2013 08:58 AM
Pioneer74
Audio Systems
Nov 5, 2012 02:38 PM
goosehntr
Oct 8, 2012 05:49 PM
Pittsburghglide2010
Jun 27, 2011 01:59 PM
