RCA "Y" splitters
Old Jun 25, 2013 | 10:11 AM
Braveheart1222's Avatar
Braveheart1222
Originally Posted by UltraNutZ
ok just so I'm clear on this;
  1. I have no clue what bike you have RG ultra 2013
  2. You have a SS PN4.320D amp and PN2.350
  3. You have a Clarion VZ401 head unit
  4. You have 2 pair of Polk DXi650 speakers in the fairing/lowers (4.320 amp)
Is there ANYTHING else in your system that I need to know about before giving advice on this setup?
edited above... thx
Old Jun 25, 2013 | 10:12 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Braveheart1222
edited above... thx
ok what's the 350 for?
Old Jun 25, 2013 | 10:44 AM
UltraNutZ's Avatar
UltraNutZ
going to go on an assumption here.
GP probably told you to wire the front RCA outputs of the head unit into RCA Y adapters then plug all 4 of those into the PN4.320D which is correct. Each speaker though IMO should be wired to its own output/channel on the amp as this amp has plenty of good clean power to drive those speakers.
The rear RCA outputs of the head unit are going to the PN2.350D for saddlebag lids I assume or is it rear tourpak pods? What speakers are in there?
Old Jun 25, 2013 | 10:48 AM
Braveheart1222
second amp running 2 pair of speakers (6.5 CDTs and 6x9 RF Txxxx)
Old Jun 25, 2013 | 10:53 AM
Braveheart1222
Nope, the key point missing from his instruction was Y rca splitter... (which I thought was odd) And he could have very well thought that would be known... can you provide a link of the correct splitter? I don't want to assume that I purchasing the right piece... THX..
Old Jun 25, 2013 | 11:45 AM
GLACIERPEARL's Avatar
GLACIERPEARL
He has 2 amps and 2 pre ampouts. Irecommended to hook 1 amp to each pre-amp, run the 4 ch amp o thefront 4 spwakers, and the 2 ch ampon the rear wiredin parallel, aslog as they were both 4ohm........
Old Jun 25, 2013 | 01:17 PM
UltraNutZ's Avatar
UltraNutZ
Gotcha..
Old Jun 25, 2013 | 01:24 PM
UltraNutZ's Avatar
UltraNutZ
ok braveheart1222.. I looked into the setup a little more and here's my suggestion.
Leave the rear speakers and amp wired as you have it now because you're going to need the power of the 350D to drive those RF speakers. They have an "ok" sensitivity rating which usually means more power to them will make them perform better.
The 320D though, I still think (if this is not the way it's wired currently) that you get 2 y adapter RCA cables (1 female to 2 male), plug 1 into each of your left and right RCA cables currently going to the 320D, then plug all 4 of those into the amp. Now wire each speaker to each a channel so you're running 4 channel inputs, and 4 channel outputs.
Old Jun 25, 2013 | 03:59 PM
GLACIERPEARL
Sure don't get this,......although I've never seen a SS amp......
Old Jun 26, 2013 | 07:35 AM
Braveheart1222
Thank you very much... does it matter whether the cable it 1 male to 2 females? or it has to be 1 female to 2 males?
