yeah that rounded case is going to help with the roll of that outer fairing cap.
Originally Posted by floridapoolboy
Hey Nutz, you da man! I was gonna ask if you could measure up an SS amp, thanks. Here's the funny part, the PPI i520.4 I bought measures 10 1/2 inches from the RCA jacks to the end of the terminal block, that's less than the SS! Now I need to check on the width, I know the SS is thinner but the PPI has a tapered case that may help me out.
Too bad you can't choose more than one! I have an Arc 125.2 that I installed 3 years ago - it's an awesome amp. Now that I've added a detachable tour pak for mama, I'm going with a SS 2 channel nano amp to power the pods.
Like others have said, not sure you can go wrong with any of them!
Well I don't see an option for what I believe to be by far the best Class D Amp on the market.
I am running 2 of the Alpine PDX-F6 600/4 amps.
No they do not fit in the fairing but they are powerful, under rated from Alpine ( mine benched in at 181 watts per channel before clipping and the other was 176 watts per channel before clipping.
They run cool as a cucumber. I have had these cranked at near max volume for hours and they stay cool!
