streetglide speakers
Old Aug 20, 2013 | 09:47 AM
hardheaded's Avatar
hardheaded
Default streetglide speakers
not wanting to run an amp at this time, what speakers are going to give me the biggest bang for my buck?
Old Aug 20, 2013 | 10:07 AM
rbferg's Avatar
rbferg
The Polk MM651's are what allot of guys including myself are using. Without an amp you're limited to running 2ohm speakers and the Polk's are 2.7ohm which is close enough. You will also need 6.5" speaker adapters. I would highly recommend that you add a amp in the near future, as the Polk's like power. If you'll only be running two channels the Rockford Fosgate PBR300x2 can be found for little $$ on eBay and amazon and is a great amp.
Old Aug 20, 2013 | 10:48 AM
UltraNutZ's Avatar
UltraNutZ
"at this time".. key words. If you're planning a 2 channel amp then you might just want to make the move now to the Biketronics Bt7P1 7.1". They are 4 ohm so they'll have a little less output per volume setting on the radio but you'll be able to hear them just fine. This will set the stage for you to add something like the SS PN2.350D or RF PBR300x2 amp at a later date
Old Aug 21, 2013 | 06:50 AM
JMJOHN's Avatar
JMJOHN
Sponsor
Hardhead ,,,,,,
without running an amp, these are the best performing speakers that I know of for your StreetGlide http://www.jmcorp.com/ProductDetail....D=HCSK-7252GTM ,,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Aug 21, 2013 | 01:25 PM
Streetrockking's Avatar
Streetrockking
This is exactly what I would do. You will add an amp soon. Its a never ending process. I would stay as far away from the J&M products as possible.
Old Aug 21, 2013 | 02:18 PM
1sweetglide08's Avatar
1sweetglide08
Look for a used set of HD Boom speakers. It will be an upgrade from stock and not alot of out of pocket expense.
painey
Audio Systems
May 23, 2019 02:49 PM
TO34
Audio Systems
Jul 12, 2015 07:11 PM
Softy 103
Audio Systems
31
Oct 19, 2014 09:08 AM
fxdi_flhx
Audio Systems
18
May 6, 2014 08:10 AM
Red.Road.Glide
Audio Systems
Sep 13, 2012 02:21 PM
