Installing Throttle-Up Speaker Adapters
Old Aug 29, 2013 | 06:35 PM
timeighty5's Avatar
timeighty5
Default Installing Throttle-Up Speaker Adapters
Any one here done it? Any pro tips I should know about?
I'm especially worried about drilling pilot holes in the adapters while they are attached to the fairing.
Old Aug 29, 2013 | 07:27 PM
UltraNutZ's Avatar
UltraNutZ
go easy.. not sure why you need to drill holes though.. do they not come with holes already drilled?
Old Aug 29, 2013 | 07:50 PM
timeighty5's Avatar
timeighty5
Holes are predrilled to mount to the fairing. Holes are not predrilled to mount to speakers to the adapter.
Old Aug 29, 2013 | 08:31 PM
acchd's Avatar
acchd
I've done some of these. The bottom screw (longer 1.25" pan head screw)holds speaker in place then u drill remaining screws holes speaker to bracket. Remember bottom inside screw isnt used mount bracket. Just go slow I used a 5/32" drill bit worked good for the remaining holes & use short pan head screws for mounting these.
Old Aug 29, 2013 | 11:12 PM
timeighty5's Avatar
timeighty5
Thanks! I used a 9/64 to drill holes to be safe. I also went to Lowes to buy #10 metal screws. The screws that Throttle-Up sent were #8 metal screws. I wanted to match the fairings screw holes exactly. Changing screws only cost me $2.
Overall it was pretty easy. I read through the directions 3 times to make sure I did it correctly.
nsdhoward45
Audio Systems
Apr 16, 2019 06:00 PM
COZWV
Audio Systems
Apr 2, 2016 06:21 PM
Peculierboy
Audio Systems
Aug 21, 2014 10:34 AM
JerryK73
Audio Systems
May 2, 2014 09:02 AM
bluflstc
Audio Systems
Jan 27, 2014 02:02 PM
