The Official 2014 audio upgrade thread
you stated this:
I used the BT recommended flash and mine screams. It's the 00_OFF flash. Loud and clear as a bell with all working controls. Less than $300 total invested.
I am using Harley amp and Harley speakers for your $300 what are you using? Just speakers speakers and an amp?
Again I am trying to figure out if there is a better bin file for the Harley setup than the one they loaded,
you stated this:
I did the install with the polyfill filling the entire plastic housing and mounted the speakers on the outside of the plastic housing and left the factory speaker grills in the bike. Of course the kicker grills won't fit like that.
So, it's loud. Sounds great with the motor off and becomes a different but not terrible sounds with motor running. Going 80 is a different story but I think I've decided that nothing with a 2 speaker setup is probably sounding great at 80. It's louder for sure and can be heard but starting to wonder if it was worth it even though I spent very little.
I think I'll try upgrading to the newest software to see what that does. Maybe I'll try a dealer flash or magic box if that doesn't help the sound quality at speed. This shouldn't be this hard...why must they mess with stuff like this?
Also, I'm a little unsure of what you guys are calling inside versus outside mounting of the speakers. Are you taking in versus out of the white plastic box?
If you split the pods and mount the speakers so you look at them thru the speaker openings is inside.
Dont know if they sell them separate but you need something in place of the pods seeing how it is
a support for the fairing.
14 SGS added Arc 125.4 amp and Focals in the fairing. Originally had Focals inside of pods as shown above. Also, originally had first flash recommend by Rockford done - 135_OFF. Eq was flat. And flat isn't even the right word. Even adding the Eq of your phone to the input source didn't make it sound great. Also, had such low volume coming out of the head unit that the amp gains were way up. Wasn't happy at all and barely better than stock.
Anyway, finally had it reflashed per the new instructions from Arc and Biketronics - 00_OFF. Never liked the speaker pods - especially after I hacked them up to install the speakers inside. I went ahead and ordered the brackets from Biketronics. $200 by themselves. Installed easy enough. Wrapped polyfill around the speakers when done and readjusted amp with multimeter. I can tell you that correct flash made all the difference in the world. Those Focals are amazing when given a good signal. This 2 speaker setup isn't super loud and there are speakers out there that will handle more power, but the quality is terrific. I can't say for sure if the brackets made much difference as I did most of it all at once, but I do think they help. They certainly give you more room. I would buy them again
Hope this helps someone in the same boat.
