Fluke 23III
Old Nov 4, 2013 | 06:56 PM
Da Shadow's Avatar
Da Shadow
Default Fluke 23III
Is this the type of multi-meter you use to set gains on an amp? All the info on here got me to looking at another system I have and it has gain adjustments so thought I would check it. Actually I'm going to replace the speakers and head unit and see if the amp is wired the best way for max power out. I'll probably replace the amp if the first two changes don't give me what I want. Thanks
Old Nov 5, 2013 | 07:00 AM
UltraNutZ's Avatar
UltraNutZ
any true RMS multimeter will suffice. You can probably pick one up at walmart that is fine.
Old Nov 5, 2013 | 07:22 AM
Da Shadow's Avatar
Da Shadow
I have a Fluke, mostly use it for continuity and voltage checks for everything but electronics. Thanks
mstng5point0
Audio Systems
44
Nov 1, 2017 06:18 PM
123ozzie
Audio Systems
19
Nov 14, 2016 08:59 AM
Makdaddy
Audio Systems
Aug 25, 2016 01:52 PM
just plain john
Audio Systems
Jun 18, 2016 08:31 AM
Tailwind
Audio Systems
May 2, 2016 09:14 PM
