Boom audio help please...
Old Nov 11, 2013 | 11:14 PM
dellagratti's Avatar
dellagratti
Default Boom audio help please...
I bought this used from a friend, I installed it today and wired it all up, what I think is correct, but its not working properly. It turns on but it emits a crazy a$$ noise. Can someone who knows what the problem/fix is share it with me and whom ever else needs the info? I have a 2001 Fat Bot FLSTF.
OVER VIEW OF WIRING
The Splice: Its Orange/White spliced to Orange/White from wire bundle
This is the kit recommended in instructions. Dont know if it is truly needed
This is the noise I mentioned above.
Old Nov 12, 2013 | 06:52 AM
UltraNutZ's Avatar
UltraNutZ
you should have a ground, main battery wire and a remote turn on which would obviously be the orange/white wire.
I think where you tapped in for orange/white is not correct. easy way to test is simply hook the orange/white to the battery temporarily to power the unit for testing. If it still does it, you've got a bad unit.
Old Nov 12, 2013 | 10:16 PM
dellagratti
Ultra Nutz i did what you recommended plus I used the wire adapter i bought and it still made that noise. Guess im screwed.
Old Nov 12, 2013 | 10:54 PM
dellagratti
to the top...
Old Nov 13, 2013 | 04:38 AM
UltraNutZ's Avatar
UltraNutZ
if you connected both the power and the ground to the battery, then yeah it sounds like you have a bad unit.
texashillcountry
EVO
May 19, 2016 03:14 PM
sn95bullitt
Mar 25, 2016 07:15 AM
tylthom7
Audio Systems
Mar 15, 2012 09:33 AM
lennieseratt
Electrical/Lighting/Alarm
Feb 19, 2011 08:16 AM
NKBIGN
Dec 16, 2009 04:41 PM
