I'm trying to install this unit on a '12 Limited with the SS amp and scott's relocation bracket. The unit installed with no problem on the bracket under the radio. The problem is finding a place to put the wiring/adaptor so the fairing will go back on. I've had to way away again for the 100th time because its pissing me off, nothing has worked. Any suggestions from anyone running a similar set up?
do you have the old clunking looking gender bender box? I found a way at the vendor site to remove it completely and then I did not have the issue with space in the fairing.
Should be the latest generation, ver 1.3.8 on the software.
Test fitted the fairing w/o the headlight and everything cleared. Headlight was hitting the wire bundle coming of the radio adaptor. I guess I'll re-tape them so they go up and right. If not, I'll guess I'll try Nascar's re-wire.
i have the same set up but with the CB module too. I used large wire ties to pull things out of the way of the fairing. a lot of the Iron Cross wires fit into the cavity under the triple clamp. I pulled it all away from the bike and the wiring harnesses that moved around and folded the easiest i stashed away first using every cavity i could find trying to make sure nothing extended beyond the two metal fairing frame pieces that the sides of the radio bolt too. This probably is not much help without pix. Sorry. It will fit just walk away when pissed........
