UN, do I have to have a HD dealer activity the rear speakers software on my HK head unit. I'm installing the speaker lids on my street glide. Thanks in advance Please advise
Thanks UN, one more quick question has any one devised a quick disconnect for their speaker wiring in the bags so you can remove the bags completely from the bike????
Thanks GP, if the hog tune kit wiring doesn't have quick disconnects I'll be using the Deutsch connector....
Still looking for the answer to this question: do I have to have a HD dealer activity the rear speakers software on my HK head unit. I'm installing the speaker lids on my street glide.
UN should confirm this, but I think you need to enable the rear speakers at the dealer if you want the fader control, if I remember UN told me 1/2 hour labor to enable.
I was going to do this, but my SS running 2 POLK 6.5's is more than enough power. I can hear the stereo above my BUBs at 80 MPH.
The speaker outputs for the rear are already active. They are pins 1,2,24,25 on the 35 pin connector. If you want the fader to work you'll need to go by your dealer to have that flashed
Do you guys think the sound stream 4.520d is a better choice than running two of the pbr300x2 amps.im ready to Oder a amp right now but I know I will be adding speaker lids soon as well and trying to plan ahead alittle. Would 2 of the pbr amps sound better than the sound stream?
you'd be looking at 100x2 for each of the PBR amps and 100x4 for the Soundstream. IMO they are both great amps and I guess the determining factors should be;
do you have room for 2 amps?
$125-ish for each PBR vs $90 for the SS
FM interference on the SS amps
Gentlemen, I have another question all my fairing speakers are 2 ohm am I going to run into trouble if I run a 4 ohm speaker in the saddel bag lids want to do the pioneer ts-d6902r in the bags with a j&m 4 ch 500w amp I got a killer deal on here in the classified section.... Please Advise,,, Thanks & Merry Christmas to All !!
