Tweeter pod
Old Jan 30, 2014 | 08:17 AM
FSCparrothead's Avatar
FSCparrothead
Default Tweeter pod
Does anyone know if the tweeters on the Hogtunes tweeter pod can be replaced? Im looking at doing a new stereo and I have a nice component set in the garage that I bought a for a build several years ago that im thinking about using.
If anyone knows or has a better option please let me know. Also during the summers here we almost always get a decent storm between 1-4 in the afternoon only last an hour or so but its not uncommon for me to end up riding in it. Should I really be concerned about running marine grade equipment?
Old Jan 30, 2014 | 08:39 AM
camsmith's Avatar
camsmith
Yes. You can replace em. I installed the tweeters from a set of Rockford Fosgate T-1652s components in mine. In my experience "marine grade" is not needed. I have never run marine grade anything and have been WETTT.
Old Jan 30, 2014 | 10:45 AM
GLACIERPEARL's Avatar
GLACIERPEARL
The cheap tweeters, are just that, CHEAP........You could get a mid-range cost, set of tweeters, in the $70 range, that are night and day better than the Hogtunes......All of the big brand vendors have good tweeters available ...
Old Jan 30, 2014 | 11:35 AM
floridapoolboy's Avatar
floridapoolboy
I replaced the Hogtunes tweeters with Polk silk domes, it was a real PITA. The Hogpod can't simply be drilled out, you need to find a replacement tweeter that will fit into the recess. The Polks needed to be removed from their plastic shell, which wasn't easy as they were hot glued in there!
shaneballance
Audio Systems
Apr 11, 2019 08:42 AM
Makdaddy
Jan 7, 2018 04:43 PM
roussfam
Audio Systems
Nov 29, 2015 11:24 PM
bald1der
May 12, 2012 08:02 PM
bowman78
Apr 1, 2012 02:41 PM
