I want more!!!
Old Feb 21, 2014 | 09:02 PM
0ldhippie's Avatar
0ldhippie
Don't know how much different the RG lowers are? Fairing Factory makes speaker pods for non vented lowers. Move your polks to the lowers and add another pbr in the fairing for some biketronics 7.1s. Should more than double the sound.
Old Feb 22, 2014 | 06:47 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Gnarl78
I set my RF PBR300X2 gain to approx. 7, and adjusted my HK head unit fader to favor the Polk MM651s in the fairing in order to balance the sound as the fairing speakers did not sound as loud as the speakers in my rear pods (the new 5.25 J&M speakers).
you have a pbr300x2 and using a fader? what other equipment do you have sir because something is missing out of this equation
Old Feb 22, 2014 | 06:51 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by yzergod
I think I'll start by bumping up the gain a bit.
good move. Set your gains based on the sticky, either ear or DMM. If you blow the MM651 speakers, replace them with the BT7P1 7.1" from Biketronics.
Being one that loves high end audio, I want my bike to be as loud as a new CVO system.
I hear Walmart is having a sale on Boss Audio
My point is set your expectation higher than CVO.
Old Feb 22, 2014 | 09:33 AM
klimoman's Avatar
klimoman
Just out of curiosity, how many watts does a CVO system have?
Old Feb 22, 2014 | 09:41 AM
UltraNutZ's Avatar
UltraNutZ
depends on the CVO.
usually 160w total
Old Feb 22, 2014 | 01:21 PM
Gnarl78's Avatar
Gnarl78
I have a '08 CVO Ultra. The PBR300X2 is in the fairing driving the Polks. The CVO amp is under the tour pak and is driving the J&M speakers in the rear pods. I have the stock HK head unit and handlebar controls.
Old Feb 22, 2014 | 07:13 PM
yzergod's Avatar
yzergod
Read the sticky... on my way!
Ouch! I guess what impressed me about a CVO system was that I could hear it clearly on the other side of the showroom. I know there are higher end and better quality sounding systems.
I want what I have to be at it's optimum.
Thanks again though UN! You should be getting a commission!
Old Feb 23, 2014 | 08:02 AM
UltraNutZ's Avatar
UltraNutZ
my system sounds like a concert hall sitting in my garage which is 1200+ sq ft. Get it out on the road and it's a total different animal
Old Feb 23, 2014 | 08:28 AM
Bigboyride's Avatar
Bigboyride
Very true I'm sure, but I will bet that it still sounds great at 80!!!
Old Feb 23, 2014 | 09:41 AM
UltraNutZ's Avatar
UltraNutZ
well it does but the point was it sounds SOOOO much better sitting still. Enclose it in a space such as the CVO on the showroom or mine in the garage and it sounds that much better.
OP, take that CVO for a ride, then come back and tell us what you think.
