Help!!!!!!!!!!
Old Mar 25, 2014 | 12:20 AM
jeremysj71's Avatar
jeremysj71
Ok in removing amp it seems the radio and amp have a wiring harness integrated to both units. Do I need another harness or is it simply plug and play
Old Mar 25, 2014 | 02:32 PM
Sire2Twins's Avatar
Sire2Twins
The PBR amp isn't going to be a plug and play. UltraNutz has a sticky in this forum with install instructions for exactly what you are doing. Follow those instructions and you can't go wrong.
Old Mar 25, 2014 | 11:55 PM
jeremysj71's Avatar
jeremysj71
I seen that sticky. My question is I will have to cut into the harness? Unplug the amp and get the out puts from there. What I have from head unit to the amp is a plug and play harness . I was hoping to find a stock harness with no amp that way I don't have a power wire hanging out in my harness not used. I will try to take a picture of what I'm talking about tomorrow .
Old Mar 11, 2017 | 01:21 PM
Pdiddle's Avatar
Pdiddle
1st Gear
Any luck?
Old Mar 11, 2017 | 01:41 PM
Roadie13's Avatar
Roadie13
Originally Posted by Pdiddle
Any luck?
3 year old thread bud, what are you looking to do?
Old Oct 6, 2024 | 04:57 PM
Dsoukup's Avatar
Dsoukup
6th Gear
What sticky are you referring to. I need the same help
DK's Limited
Audio Systems
Nov 18, 2018 09:03 AM
zigzag930
Audio Systems
Jun 9, 2017 03:44 AM
RSDUDA
Audio Systems
May 20, 2014 02:24 PM
JohnnyBoy
Audio Systems
85
Aug 2, 2013 08:49 PM
Loop4re7
Feb 1, 2013 07:25 PM
