RF amp install change
Old Mar 27, 2014 | 07:53 AM
Kidharley's Avatar
Kidharley
Default RF amp install change
I see on the RF website they say to run the ground directly to the battery and not to the fork. They have put out an install advisory. Has anyone else done this? I see people are still grounding theirs to the forks or frame. Going to be installing mine on Sunday and want to do it right the first time. I'm not much of a 12 volt expert.
Thanks, Jeremy
Old Mar 27, 2014 | 08:25 AM
keno's Avatar
keno
That RF update has been in place for a while. I ran mine directly to the battery..
Old Mar 27, 2014 | 09:44 AM
ElectraGlideSteve's Avatar
ElectraGlideSteve
I'm installing mine next weekend when my speakers arrive and will run the ground from the battery.
They have found there's too much resistance when grounding to the chassis.
Old Mar 27, 2014 | 10:53 AM
AAWAV's Avatar
AAWAV
+1 - see sticky notes... UltraNutz
Old Mar 27, 2014 | 10:59 AM
zeke383's Avatar
zeke383
^^^^ That
Mine even came with a seperate paper instructing to do so
Old Mar 27, 2014 | 11:14 AM
RatPwrd72's Avatar
RatPwrd72
Yep. If you buy the RFK-10 install kit, there's enough power wire (red) to make both the ground and power wire from it. Be sure to mark the ends of the Red ground wire Black so as not to reverse the polarity at the amp.
Nismogsxr
Electrical/Lighting/Alarm
Feb 14, 2018 03:25 PM
speedracer
Audio Systems
Mar 15, 2015 07:55 PM
Big Blue Hog
Audio Systems
Sep 24, 2014 03:45 PM
remerson
Audio Systems
Mar 27, 2014 11:05 AM
WVleo
Oct 27, 2008 07:13 AM
