Power Vision interfering with handlebar controls (Biketronics)?
Earlier this week I re-positioned all and drove around the neighborhood without outer faring on. all fine...
put fairing on, took bike out for another round all fine (without the Power Vision connected; got bracket in the middle/top of my fairing; wire running through central wire gutter under tank and though fairing up and out in the middle of the windshield between fairing and windshield though a small hole).
Today - again took bike out again and installed the PV. as soon as I hit the volume up second time... boom next song. So stopped over and disconnected the PV. Drove around and all was just fine...
so, anyone out there that has/had similar behavior? I cannot recall having the same issue when I had the PBR200x2 in the fairing (got SS4.520 now)...
I will - again - take fairing off and route the PV cable differently to see if this will help.
FYI I like to keep my PV on the bike all the time as I am one of those that needs to calculate all kind of info in my head while driving (OCD?).
I know for a fact it was working just fine previously. maybe lift the tank again and change the PV wire in the wire channel.
I will also contact FuelMoto to see if they got any idea...
AAWAV, you'd probably be better of contacting DynoJet directly.
At no point does it touch or get near any of the control wires or gage wires. If you guys are running it thru the fairing, might be worth a try to re-route it and try again.
Those PV wires are very touchy! I am on my 3rd PV cable in 2 years. First one got pinched. 2nd one was scuffed and I think signal was leaking or getting in. Both of these times, The pv its self would be on but go "blank" as in no data.
But I never had a problem with Audio and I have a ton of Audio wires running right along side the PV cable.
as - I believe - Dynojet is here in Vegas, I will contact them directly (per suggestin of UN) and keep you all posted...
tried to call Dynojet - "busy" signal.
Called FuelMoto (I bought from them) - they have never heard this. I promised to let them know the outcome... As they are an outstanding Vendor
Emailed Dynojet with specifics and if needed I can drive over to them to actually show it to them.
Now, on a side note... read a little bit about wire shielding... of course not sure if this is the actual cause, but I do have "aluminum" tape here that conducts current (measured with multi meter). I am just curious if taping at least the PV cable part in the fairing with the tape and optionally ground the tape to the chassis. Anyone got an opinion on this?
If I do not get an answer today, I might open op the fairing (AGAIN for the xxxth time) and give it a shot.
Keep you posted.
