amp recommendation
Old May 8, 2014 | 07:49 AM
positive charge's Avatar
positive charge
6th Gear
Default amp recommendation
i had Iron Cross install the pre amp mod and now I want an amp to go with it, I have some RF 6.5 speakers installed. how about some recommendations, i plan on staying with just the fairing speakers. i also would like to keep the fm. thinking the rf 300x2.
Old May 8, 2014 | 08:03 AM
Gannicus's Avatar
Gannicus
The X2 is a great place to start. . . lol
Old May 8, 2014 | 08:28 AM
GLACIERPEARL's Avatar
GLACIERPEARL
What model # are your RF speakers ??
Old May 8, 2014 | 08:35 AM
Pioneer74's Avatar
Pioneer74
If you were going to use the 300x2, you could have saved your money and not done the pre-amp mod. The pbr likes the high input gains.
Old May 8, 2014 | 02:57 PM
positive charge
6th Gear
speakers are t165's, i don't have to use the pre amp. i was under the impression that it would drive a cleaner sound thru the amp. should have asked before i did it. thanks again for the help.
Old May 8, 2014 | 03:00 PM
howitzer88's Avatar
howitzer88
I have the RF300x2 with BT 7.1's on a stock HU running hi-level inputs (AP mode). Sound is awesome at 75 MPH.
Old May 8, 2014 | 04:02 PM
Fozzy4325's Avatar
Fozzy4325
Originally Posted by UltraNutZ
In no specific order:
SS PN4.520D
SS PN4.320D
BT4180
J&M JMAA-3600H / ARC KS 125.4 Mini
Alpine KTP445U - main reason I include this one is because it's very small and packs a pretty good punch, 2 ohm stable to wake those BA speakers up, is inexpensive, has good specs, and is a helluva upgrade from stock
I would have to say performance wise, taking all things into consideration, and $ was no object, the toss up would be between the 4180 and the J&M/Arc amps.
Most bang for the $ definitely goes to the SS amps if you can live with the FM issues.
this was from a thread I posted a while back
FrenchieM
Audio Systems
Jun 30, 2017 12:20 PM
equandt
Jun 4, 2015 05:44 PM
lowglidin
Audio Systems
Dec 26, 2014 04:21 PM
ronherman
Audio Systems
20
Jul 21, 2013 09:43 AM
dgb
Mar 22, 2012 06:44 PM
