SG boom amp and spkr upgrade
Old Jun 1, 2014 | 05:00 PM
jt metal's Avatar
jt metal
Default SG boom amp and spkr upgrade
Thought it was a simple plug and play. Well.....I need help with opening connector s to add pins from New harness. Most of the instructions say * refer to service manual. Just not my bag. If anyone can help . I'd like to send you my #. Thank you.
Old Jun 1, 2014 | 06:23 PM
GLACIERPEARL's Avatar
GLACIERPEARL
It's a stretch to call the Ka-Boom an upgrade !!
Old Jun 1, 2014 | 07:07 PM
jt metal's Avatar
jt metal
Lol, well......
Old Jun 1, 2014 | 09:12 PM
jt metal's Avatar
jt metal
Alright, it comes down to two pins. One yellow/orange one yellow/brown. It's a separate lead coming off the main amp harness. Everything else is accounted for.
Bike is a 2012 street glide. Any help or ideas will put this thing to rest. Thanks!
Old Jun 2, 2014 | 07:12 AM
UltraNutZ's Avatar
UltraNutZ
how about some part #s please.
part # of amp
part # of wiring harness
Old Jun 2, 2014 | 09:35 AM
jt metal's Avatar
jt metal
Old Jun 2, 2014 | 09:46 AM
jt metal's Avatar
jt metal
Top harness is radio
Bottom harness is amp.
There is no small two wire radio lead coming off the radio harness.
H.D. # 76000074
Old Jun 2, 2014 | 09:47 AM
UltraNutZ's Avatar
UltraNutZ
ok so you know where they go just needing to know how to pull connector apart to fit them in there is that what I'm understanding?
Old Jun 2, 2014 | 10:17 AM
UltraNutZ's Avatar
UltraNutZ
looking at the directions, the service manual wiring diagram jogged my memory a little.
that 6 pin connector is actually attached to the fairing bracket on the bike. Unplug it, plug one end into the 35pin connector harness, plug the other end into the 23 pin connector harness going into amp.
Old Jun 2, 2014 | 10:18 AM
jt metal's Avatar
jt metal
There is no two wire lead to connect 4 & 5 with? Maybe I could cut the sleeve back on the radio harness? Could expose the two wire lead off the radio harness.
