Thinking about a almost complete redo...
Old Jun 11, 2014 | 02:54 PM
Eshaw301's Avatar
Eshaw301
Default Thinking about a almost complete redo...
I am seriously thinking of upping the game a little bit but I need some advice. I currently have the following installed...
1. Kappa 62.11i up front
2. Two each TS-D6902R in the bags
3. XD400/4 amp.
Before I went to the XD400/4 amp, I had a PBR300x2 pushing the front speakers and an Arc 125.4 pushing the rears. The rears would beat HARD in the bags with that amp (in parallel) and the infinity seemed louder as well. The problem was that the PBR300x2 would clip at certain sound levels, regardless of the gain setting and the Arc lost the front two channels (this was the reason I installed the PBR for the kappas). Seems to me that those Kappas require a lot from an amp and so far so good with the XD400, except for the output. Its measly at best, but the amp is super efficient.
I now want my beating bags back and am looking at adding another pair of 62.11 in fairing lowers. Here's what I am planning....
1. Two BT4180 amps, one for the front and one for the rears
2. Adding an additional pair of kappas to the fairing lowers.
My question is this...is the BT4180 that much better than other amps?The reason I ask is because I think the $600 selling price is extremely high. I would do two of the Arc 125.4 but I already burned up one with the Kappas. I want to do this one more time and want to get it perfect this time. Is there another amp that is comparable to the BT4180 at a lesser cost? Saddlebag installation of the amp is not an option. I dont have a tour pak and dont plan on buying one. What are your thoughts on this? Thanks.
Old Jun 11, 2014 | 05:11 PM
floridapoolboy's Avatar
floridapoolboy
Lots of rave reviews for the BT amps, but until someone puts one on a test bench no way to know for sure. Good luck!
Old Jun 11, 2014 | 08:06 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Do you think that two of the 4180's will fit under the fairing ??
Old Jun 11, 2014 | 09:54 PM
Gannicus's Avatar
Gannicus
3. XD400/4 amp.
You would have to get on GP's and Nutz's level of amps to get the power equal to the 4180. i.e., Alpine F6, JL 600/4, Soundstream TN4.900. With all the restrictions you laid out, nothing in the saddlebags, nothing in the tour pak etc., Your choices are limited in the fairing for the power you are after. X2 or 4180 Thats it. Just saying. . . .
Old Jun 12, 2014 | 04:42 AM
GLACIERPEARL
This is a PRIME example of why I always say, " Go overboard the first time ! Do it once, do it BIG ".........some guys keep chasing the 'high' until they've spent 3 times what it would cost to do it 'right' the first time !!
Good luck in your quest !
Old Jun 12, 2014 | 05:14 AM
Pioneer74's Avatar
Pioneer74
Not a chance.
Old Jun 12, 2014 | 05:24 AM
Pioneer74's Avatar
Pioneer74
I'll add another thing here. I was told that the 4180 is ~230 watts a channel at 2 ohms. If that's true, your Kappa speakers won't last long with that power.
IMO, without mounting anything in the bags, the best you can do is run 4 ohm speakers in parallel if you plan to add lowers. Then you could do a 4180 on the top of your radio for the four bag speakers and maybe a Sounstream 2.350 on a Hogtunes 2nd amp bracket. Or use those amps just with the Kappas in the fairing.
Old Jun 12, 2014 | 11:35 AM
Eshaw301's Avatar
Eshaw301
Based on the dimensions of the BT4180, they should sit perfectly fine inbetween the glove boxes and inner in the fairing of the roadie. We'll see how it goes in a few.
Old Jun 12, 2014 | 11:38 AM
Eshaw301's Avatar
Eshaw301
Yeah im looking into it now and from what I see the amp rating remains 180 at 2 ohms. I have never seen that before, but it's worth a shot to me.
Old Jun 12, 2014 | 11:40 AM
Gannicus's Avatar
Gannicus
Well if they don't fit and you want to sell one of them . . . Put me on the list!
