HELP! On road, new system problems
Old Jun 28, 2014 | 06:40 PM
1HD2NV's Avatar
1HD2NV
Default HELP! On road, new system problems
As most regulars know i just finished my install Thur. On 1st day of 10 day trip & left Pro has quit working. Balance right all well, balance left nothing. Swapped speaker wire & opposite happens. What else can i check??? Hate to think Pro bad already. Not looking forward to 3k journey with only 1 speaker. REALLY appreciate suggestions if there is something else i can try! Reversed white/ red RCA's with no change but not thinking i am approaching that right.
Old Jun 28, 2014 | 10:48 PM
09B29's Avatar
09B29
if you switched RCA plugs and left was still out id say you have a bad speaker
check the solder connections on the speaker terminals
Old Jun 29, 2014 | 10:19 AM
Moto Mike's Avatar
Moto Mike
I'm confused "swapped wires and opposite happens" you mean opposite speaker doesn't work, or opposite channel....?? So when you switched wires was the left speaker still dead? If it was then speaker probably gone.
Old Jun 29, 2014 | 05:09 PM
1HD2NV's Avatar
1HD2NV
Yes, left speaker still dead. Meant when I swapped speaker wires I could then fade left & with the left speaker wire hooked to the right side speaker the good speaker still worked. Fade right & with right side wire hooked to bad left speaker nothing. Guessing this rules out HU, & maybe even amp....
Old Jun 30, 2014 | 09:24 AM
Moto Mike's Avatar
Moto Mike
Yes I would agree not HU or amp.
Old Jul 1, 2014 | 06:09 PM
1HD2NV's Avatar
1HD2NV
Bill has Priority mailed me a replacement to the Hotel we will be at tomoorow night salvaging tunes for most of the 2nd half of vaca. Didnt surprise me, only 1 of the reasons I went with BT
Old Jul 1, 2014 | 07:07 PM
ridedaddy's Avatar
ridedaddy
First speaker problem post I've ever read from bt. I'm sure it's just a fluke.
Old Jul 1, 2014 | 08:07 PM
famous337's Avatar
famous337
I had a similar problem right after my install while on a 7 day trip. Left speaker took a **** about 750 miles into the trip. It was the RCA cable into the amp. Make sure the middle connections to the amp are tight, it was a simple fix for me.
Old Jul 1, 2014 | 09:26 PM
Gannicus's Avatar
Gannicus
Totally sucks! Correct me if I'm wrong but I think you were the first guy on the forum to buy the proline series? I'm curious to know how your situation turns out. Those are awesome speakers very well made and I'm having a hard time believing it's the speaker. Keep us posted please! Thanks!
Old Jul 2, 2014 | 12:36 AM
chunngle's Avatar
chunngle
Now that is customer service at its finest.What other vendor out there, regardless of the products they sell, would have a replacement part sent priority to you, let alone to your next scheduled stop while on a trip?? Top notch!!
