Lost reception and amp install ??
To start were talking 2013 FLTRX with stock HU and J&M Rokker 7.25 speakers. A guy owes me for some work and offered me a pretty much brand new RF PBR300x2 and Im going to take it because Im relatively certain Ill never see cash otherwise. Other than that Im not obsessed with audio so it should keep me happy. So heres my question:
I have the HD hidden antenna mounted already (note that it taps off the cig lighter spade tabs for power) and it worked just fine until I got the genius idea to install a USB charging port in the glove box and used mini-taps to tap into the power supply. Of course I tapped into the cig lighter line for the USB charger, confirmed that it had power and would charge my phone, and slapped the fairing back on and headed down the road as happy as a pig in s***. The next day I turn my radio on and of course no reception at all, the only thing that has output is the CD and aux port. Take the fairing back off, pull the taps for the USB charger and of course the reception is fine.
I still want power to my USB charger and I want to keep the hidden antenna set up. Do you think I lost reception simply because Im pulling too much current off the line to the cig lighter or is the USB charger interfering with the hidden antenna and causing the loss of radio reception?
I guess the other easy power supply to get to is the lights. Should I move the USB charger to tap off one headlight and then tap off the other headlight for the on input for the amp when I get it? Or leave the USB charger on the cig lighter and move the hidden antenna to the light for power? Am I just asking for more problems having stuff tap off the lights? If so, what else could be used for power? I thought about running something from the accessory port under the seat, but thats on the same circuit as the cig lighter and figured I would get the same interference as being tied into the cig lighter.
