Is the FM reception loss with Class D amps limited to the HK stock head unit? Meaning... if I replace the head unit with an aftermarket will I get FM reception back?
Now....I had a cheap 8.99 antenna in the fairing from AutoZone and I had the power line running next to the antenna plug and still could grab a few stations. My guess is if I run the power on the opposite side and perhaps a boosted antenna and I would be fine.
I will standby and watch what others say, but I think it is a hit or miss with this one. To answer question. Head unit does not matter, from what I have read to date.
Nope - It's the switching circuits in the class D. HU doesn't matter.
you'll have better luck making sure your power and ground wires are run on the opposite side of the wiring tray away from your antenna wire. Aside from that, it really doesn't matter where you physically place the amp. I've had some in saddlebags and lost reception and then again I've had some installed right on top of the head unit and had no effect on FM reception. It truly is a hit or miss kinda thing.
