well if you bridge the TN4.900D into 4 ohms, that's 450w/2
wire your speakers in series bringing it to 8 ohms. bridge the amp which effectively cuts the ohm load in 1/2 so you're back down to 4 ohms..
Are you saying to bridge each channel as in the positive of channel one to the negative of channel two?? Let me see if I have this correct. For speakers on left side (ch. 1 and 2) i'll wire up like this....
1. Positive on channel one to positive on first speaker.
2. Negative on first speaker to positive on second speaker.
3. Negative on second speaker to negative on channel two.
Is that correct?? And if so, repeat process for speakers 3 and 4, correct??
you are correct. I'm not in front of a computer right now but you'll need to double check by looking at the SS manual for the wiring. If memory serves me correct, you'll wire up your right speakers to the front outputs of the amp and your left speakers to the rear outputs of the amp. Obviously you'll only use 2 of the 4 speaker outputs for front and same with rear. just don't know which one's off the top of my head.
