I have a 2007 streetglide and when I'm listening to a cd and try to flip the switch up to go to the next song, it switches to the weather band station, same too if I'm listening to the radio. If I push in on the switch it still operates like it should. Just wondering if anyone else has had this problem, and what was the diagnosis? Thank you, Phil
So with a CD in the drive and listening to FM if you try to advance to another station by hitting the "up" switch it goes to weather-band...or does it go to CD??
If I'm listening to 100.7 fm and try advancing to 105.5 it goes to weather-band, if I keep hitting the up switch it goes to am, fm, cd. It's suppose to do when you push in, which it does. When I hit the switch down it works the way it should.
Sounds like a switch or harness issue, but we have more questions.
Give us a call when you can and we'll walk you through some things.
Would be better if you were with the bike.
I had the same problem, you have a bare wire somewhere shorting...open your fairing and look , poke around, lift wires, I did and found one. Problem fixed.
Sorry it's taking so long to respond I've been working 12hrs.and trying to figure this out I took the outer faring off the wires look fine, the only thing that was changed were the grips. I thought maybe a wire was pinched but didn't see any. The pink/white wire is the one to flip up stations. A buddy of mine told me if there weren't any pinched wires to unplug the harness from the radio and and find that wire check ground for a short to determine if it is the radio or the switch. After tomorrow I'm off for three days so I will have time to figure this out. Is there a number I can call you when I'm ready? Thank you.
