Aquatic A/V
AQ-MP-5UBT
Our patented flagship model AQ-MP-5UBT is the perfect marine stereo, packed with features including 3" color screen with album artwork and song/playlist data, IAP Bluetooth, USB connectivity and easy navigation via rotary **** control.
AQ-MP-5BT
The patented AQ-MP-5BT features standard Bluetooth connectivity, 3" dot-matrix display, device connection via 3.5mm jack plug or RCA inputs and easy navigation via rotary **** control.
Also might be of interest to a motorcycle environment:
Shockwave Technology brings together outstanding sound quality, high performance characteristics and unprecedented reliability in a single amplifier. Completely sealed and waterproof (rated IP66) to deal with the toughest marine conditions. Stable operating 2ohm and 4ohm speaker configurations. Digital technology and high-quality components produce true sound reproduction and reduce EMI, power consumption, strain of battery and charging systems, space and weight. Shockwave Technology is now the only sensible amplifier solution for marine installations.
I wish I was in Tampa over the next couple days (frankly, any time- NY SUCKS!!)...I'd like to talk to these guys about the "-H" parts UltraNutZ was informed about earlier, and also about that amp.
Here are the specs they list for the AQ-AD300.2 2 channel amp that was featured in their video (and is featured on their website):
Type: Class D Digital Amplifier Color: Blue Waterproof: Yes IP66 Input Channels (low-level): 2x RCA Input Channels (high-level): 2x speaker Output Channels: 2 Output impedance (nominal): 4 Ohms Power Output (RMS) @ 4 Ohms: 150W (2 x 75W) Power Output (RMS) @ 2 Ohms: 288W (2 x 144W) Frequency Response: 10Hz - 50,000Hz THD @ 70W, 4 Ohms: 0.00005 THD @ 75W, 4 Ohms: 0.0001 THD @ 117W, 4 Ohms: 0.1 Low-Level Sensitivity (RCA line-in): 200mV - 6V High-Level Sensitivity (Speaker line-in): 400mV - 12V Input Impedance: 33k Ohms Dimensions: 42.5 x 218 x 140mm Additional Features: Gold plated connectors
