Aquatic A/V
Old Jul 20, 2015 | 08:56 PM
  #41
pjones1969's Avatar
pjones1969
Recd. and installed mine today......
Install was a breeze, the search function did not work as described with my usb flash drive (must be a formatting issue) but it worked as described with the iPhone via Bluetooth so I'm just going to use it that way until I can figure it out.
The Hogtunes amp is actually wired through the 23 pin connector so no splicing was required as I originally thought, simply plug and play.
Attached Thumbnails Aquatic A/V-fullsizerender.jpg
Old Jul 27, 2015 | 12:50 AM
  #42
iHarley's Avatar
iHarley
Originally Posted by $tonecold
That should work if it has a rear usb. The specs for that radio don't say anything about a usb. That plug takes a 1 1/2" hole. I have one I would send you for $10 to cover shipping. There are other options out there if you just want usb that only need a 3/4" hole. Have you even looked at the HD1BT Jensen? I have one and it has been good so far. This looks like the best deal right now at $444.44 http://www.ebay.com/itm/like/281449390127?lpid=82 I don't see where you are getting anything with the AQ that you are not getting with the Jensen. Quality? I have not seen a lot of complaints on the Jensen.
The Aquatic AV USB is a charge only.
The Jensen HD1BT USB, with a "Y" adapter can be used for charging AND at the same time as an additonal input from any device, ie cell phone, memory stick, SD Card, etc. and stroll songs with the right handlebar control.
Jensen is far better and much cheaper!
Old Sep 28, 2015 | 05:36 PM
  #43
InTheWinda1's Avatar
InTheWinda1
Default thought
Hogtunes amp , is that made to work on 4ohm and 2ohm , thought it would not be good foe 2ohm speakers , thought strickly for 4ohm speakers ,, what ohm speakers are you using ?
thanx
JIM
Old Sep 28, 2015 | 05:39 PM
  #44
InTheWinda1
Default ?
witch hogtunes amp are you using ?
JIM
Old Sep 28, 2015 | 06:06 PM
  #45
gja's Avatar
gja
The USB can be used as an input. I needed a software update from Aquatic to run the Nano gen5.
Old Sep 29, 2015 | 11:02 AM
  #46
pjones1969's Avatar
pjones1969
JIM
I have the older one, installed it in 2009, believe it is the 902.2 and I replaced the older Hogtunes fairing speakers this year with their GEN 3 352F-AA 2 ohm
I was running an old iPhone 4 as a music only device through the usb, figured it was hooked up anyway for charging, last week I would lose all sound when I hit a bump, I would have to disengage the faceplate and reengage it and it would work again, until the next bump, even some smooth road transitions caused it to not work, I decided to change it to Bluetooth audio to narrow it down before contacting Aquatic, and bluetooth was not affected by the bumps at all, weird, must be something on the connector between the unit and the faceplate
Old Sep 29, 2015 | 12:37 PM
  #47
InTheWinda1
Default connector
Cutting out defiantly connector , been there done that - 902.2 I think is speakers . Would like to know Hogtunes AMP plug and play .watts ?
JIM
Old Sep 29, 2015 | 01:25 PM
  #48
pjones1969's Avatar
pjones1969
JIM
Think you are right, it must be the 40.4 then, 160 watt
Old Sep 30, 2015 | 05:21 PM
  #49
bigdaddy33's Avatar
bigdaddy33
I have Satellite XM radio on my stock HD HK radio. Neither of the Aquatic AV radios offers this option... yet. I spoke earlier today with Patrick, and he said it is in the works and to check back in the 1st qtr of 2016.
Also, I don't think there is a clock.
Old Sep 30, 2015 | 06:20 PM
  #50
InTheWinda1
Default no clock
No clock , that sure is surprise and never heard of radio with no clock .. , xm radio , that seams unlikely , but maybe they can add it some way , I say that because a menu is a menu , if they can and XM to menu that will B great .
JIM
