Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
E85 anyone???
Old Mar 31, 2018 | 02:39 AM
67Shuv's Avatar
67Shuv
You can retain stock compression. Flex fuel factory vehicles have one compression ratio. You need to up your jetting/fuel about 30% as stated and can add some timing. Other than that, enjoy the benefits!!!! I'd add wideband O2 capability to mine and run E85 but the hit and miss fuel availability keeps me on Gasoline where I'm at. It's really like buying race fuel at the pump in a lot of aspects.
ill add this- make sure your fittings, O rings, fuel lines, and any internal carb parts are meant to handle the high alcohol content. If not, they'll fail in short order. My original statement above was meant toward the tuning side of things, a few hardware changes are needed as well but are easily overcame.
Old Mar 31, 2018 | 02:51 AM
badcooky's Avatar
badcooky
Subscribed Murray Farkwahs !
Old May 15, 2018 | 03:11 PM
turbotom1052's Avatar
turbotom1052
Originally Posted by Wild Card
I know a bunch of guys doing it and have done it to sport quads. Naturally carb mods to deliver fuel needed which is near twice the amount for gas. Theyare adding a/f ratio gauges to monitor and keep in the 13 range. I see no issue especially with fuel injection.
One good thing is the motor will run as cool as a cucumber and you can add much timing. Down side would be more frequent oil changes due to water in oil due caused by cold running motor. Remember e 85 is not much different than alky motors used in racing apps. Same rules apply
id think 13 to 1 would be a grenade waiting to blow up running e85???
Old May 21, 2018 | 07:56 AM
67Shuv's Avatar
67Shuv
You can get away with much more compression on E85, the fuel is much more resistant to predetonation, so higher compression and tighter quench areas can be utilized and deliver much more power. It will run cooler, yes. But, not so cool you'll never get water out of the oil. It's still an air cooled V-twin. Like I mentioned before, I'd run it in a heartbeat if I had reliable fuel availability. Even then, it couldn't be a road trip bike. I'd had to be out on the road and not be able to find it. Those reasons keep me on gas.
However, my shovel has drank more than a few gallons of E90 race fuel. 12.5:1, a big Mikuni, and hot ignition. Thing is a beast. I normally start it with a gas soaked rag stuck in the carb throat, and once it builds the slightest bit of heat in the heads you're in business. It's a kick-only bike, I've built a set of rollers to put the rear wheel on for cold starts after it's been dormant a while. I start it with a golf cart, my knees aren't in shape to kick like they used to.
Old May 21, 2018 | 02:21 PM
turbotom1052
. we are talking AFR here not compression.
Old May 21, 2018 | 04:40 PM
67Shuv's Avatar
67Shuv
10-4, that's a fact then
Old Nov 14, 2018 | 04:54 PM
vycor's Avatar
vycor
What about a flex fuel type application? For my car, a Subaru BRZ, there is a kit that allows me to run anything from full e85 to 91. No need to worry about if there is no e85 around, just fill up with 91 and go. Doesn't matter if I'm on empty, or half tank or whatever with e85. Just like the stock flex fuel vehicles, just put in what is available and the ECU automatically adjusts. So is there something like that out there for motorcycles and/or has anyone done it?
Old Nov 18, 2018 | 06:19 AM
FRANK DRAGO's Avatar
FRANK DRAGO
Building e85 bike is not a problem. First off I did not see which model bike you have. You can run external fuel systems that rated for e85 that won’t eat way at pump and fuel lines and injectors. You will need a much larger pump and higher volume so you don’t max it out and the right Injectors that can be used with e 85. Also I would recommend the gauge that tells you if your gas is at e 85 not e70 or less.
Old Nov 25, 2018 | 11:48 PM
slodsm's Avatar
slodsm
And that’s lean as hell for E85. Like burn **** up lean. 13:1 compression isn’t an issue. I ran 13.5:1 on the street for 15k miles years ago and also made some seriously stupid power with turbo cars using it. Afr is going to be a lot closer to 10:1 than 13:1 for it to be healthy.
Old Jan 19, 2020 | 02:22 AM
turbotom1052
this is what im saying
jus2anoyu
Mar 10, 2014 04:53 PM
bigdork
Jul 7, 2010 11:15 PM
mumeral
Jun 14, 2010 07:51 AM
bdavis385
May 8, 2008 08:11 PM
dhc8guru
Exhaust System Topics
May 3, 2007 12:01 PM
