Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
accelerator pump
Old Apr 8, 2017 | 03:02 PM
Norm jr.'s Avatar
Norm jr.
Stage I
Default accelerator pump
I have a 1988 fxrt with a cv carb I noticed it was running rich so this winter I went through it and put a cv carb kit in it. It still ran rich. so I set it up with the air filter off and fired it up warmed it up. with the enrichment valve closed and idle mix screwed almost all the way in still rich. looking at the carb inlet it is wet with gas, with a flashlight I could see fuel dribbling out of the accelerator pump shooter, raised rpm and had a pretty good flow out of it. Took carb apart lowered float level put together and same result. Any help, advice, opinions will be appreciated.
When I was drag racing I would set a carb to do this deliberately for the needed extra fuel off the line, but this is not the case here.
Thanks in advance for your time
Norman
Old Apr 27, 2017 | 11:11 AM
br549A1's Avatar
br549A1
I'd replace the accelerator pump diaphragm and oring. It shouldn't pull fuel from there after the initial squirt when you twist the throttle. Check ball stuck I believe as well. Take the bowl off and shake it you can hear the check ball rattle is clean the bowl good and the accelerator circuit while the bowl is off
Ironhead Dave
Ironhead
25
Jul 11, 2016 09:35 AM
GT Larry
Aug 21, 2014 07:55 PM
dparsons
Exhaust System Topics
Apr 30, 2012 08:10 AM
rc51ironhead
Ironhead
Jan 30, 2009 12:44 AM
ardvark
Shovelhead
May 24, 2008 12:40 PM
