Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Backfire problems!!
Old May 14, 2017 | 06:57 PM
Tonyparson1's Avatar
Tonyparson1
3rd Gear
Default Backfire problems!!
I have a 1998 Fatboy and my question is, I put a Arlen Ness big sucker air-cleaner on it but even before that my motor would backfire every now and then, most of the time when I let off the throttle when I'm slowing down but if I pull the choke out just a little bit it runs perfect, not the first backfire, any ideas? Maybe needing bigger jet?? Right now I have a 180 main jet. Thanks for any info on this.
Old May 15, 2017 | 11:57 AM
DaddyFlip's Avatar
DaddyFlip
I'm not an expert, but I'm dialing in my bike and getting advice here. Sounds like a pilot jet or mixture screw issue (if it's only jetting). What pilot jet do you have? Probably go up a size. And then reset the mixture screw, probably a quarter to half turn out?
Old May 24, 2017 | 09:53 PM
raymint's Avatar
raymint
backfire thru the exhaust is too much fuel, thru the intake too little gas duhh I think could be basackward. someone check me I need sleep.
Old May 25, 2017 | 06:16 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Check your intake seals. Make sure you're not sucking air there... And is it backfiring or popping on decal.....? up the pilot jet 1 or 2 sizes and readjust the mixture screw. Should be 2-3 turns out if it's a CV carb....
OneHarleyAtATime
EVO
45
Sep 23, 2021 07:56 AM
Superduper
EVO
Mar 16, 2019 08:56 PM
OneHarleyAtATime
Carburetor Related
Jun 11, 2017 05:09 PM
cobra2411
EVO
Apr 1, 2012 06:37 PM
ccondon23
Exhaust System Topics
Jul 28, 2007 08:45 PM
