Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Which intake manifold--Mikuni or Harley??
Old Jan 28, 2020 | 01:53 PM
Johneb48's Avatar
Johneb48
Default Which intake manifold--Mikuni or Harley??
I have an 05 Fatboy, Big Boy's ported heads, Daytona TT, 95" SE cast flat tops and bored jugs, Andrews 37 cams, ---Which intake manifold --Do you need to use a Mikuni manifold with Mikuni HSR 42 carb or can I use harley intake manifold?
Old Jan 29, 2020 | 07:41 AM
t150vej's Avatar
t150vej
You can use a stock intake with a 42mm.
They do wear out from too many R&R's and/or running too long with a misaligned mount/backing plate. If you have concerns, you can replace it with a Screamin' Eagle 29635-99 which has a much larger carb bung and will accept up to a 45mm carb. The head spigots are the same and comes with o-rings and 2 intake grommets - one for 40/42 and another for 44/45mm carbs.
Old Jan 30, 2020 | 11:36 AM
GearheadMike's Avatar
GearheadMike
Make sure the manifold you use matches up to the 'ported' heads. You may want to talk to the head guy, or you may have to match the manifold.
Old Jan 30, 2020 | 04:01 PM
Johneb48's Avatar
Johneb48
Thanks--Good suggestion
ButtMan1000
Exhaust System Topics
Nov 4, 2012 10:34 AM
BLACK LABEL
Mar 2, 2012 07:06 AM
PapaTravis
Oct 14, 2008 10:39 PM
bjornsson
Aug 23, 2006 06:46 PM
Crankyjay
Apr 5, 2006 08:59 AM
