Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
CV Backfiring
Old Mar 28, 2010 | 07:12 PM
dc_street_glide's Avatar
dc_street_glide
2nd Gear
Thank you gsxrboy96. I will try a bigger pilot jet and leaning out the needle. Hopefully that will help. I will keep you posted on results of the change.
Old Mar 29, 2010 | 07:39 PM
gsxrboy96's Avatar
gsxrboy96
keep us updated, interested to see how it works out.
Old Mar 31, 2010 | 06:06 PM
shadylane's Avatar
shadylane
I have an '06 Street Glide, with a CV carb on it. I have Rineheart slip ons and a Screaming Eagle stage 1 intake with an Arlen Ness air filter (witch is and open element set up, open airfilter/rain sock). I have recently rebuilt and re-jeted the CV. Im getting alot of backfiring out the intake and some fuel comming back out into the bottom of my air filter. Can anyone help me on fixing these 2 problems, because no one that I have spoken with knows whats going on. Here are the specs:
46 for the pilot jet
2 1/2 turns on the air'fuel mixture screw
180 for the main jet
3rd clip positon on my needle
CVP performance slide spring (for quicker throtle response)
all new gaskets/o rings
new rubber gasket between the carb and intake manifold
Thanks for all suggestions!
My $.02 worth.
Sounds like your getting too lean when you snap the throttle open.
This could be caused by the slide opening too quick "weak slide spring" and/or the accelerator pump is too weak.
Also cam timing that closes the intake too late will cause both carb fogging and farts....
Does the Arlen Ness air filter require oil on it?
Old Mar 31, 2010 | 06:44 PM
t150vej's Avatar
t150vej
Not yet mentioned unless I missed it - sounds like you have a vacuum leak. That can happen at the carb grommet, either or both o-rings at the head, a torn, punctured or misaligned diaphram and seldom but it does happen, an enricher valve not seating correctly. If any of those conditions exist, you'll never tune the backfire out of it. A weak accelerator pump can do it, but that usually gives symptoms at higher RPMs also.
The lightweight check valve for the accelerator pump will often cause fuel slober because the vacuum pulls fuel by it thru the accelerator nozzle, acting like a siphon.
And please correct me if I'm mistaken, but they don't make a 46 jet for a CV. (anyone got part number?) 48 would be my suggestion as a minumum for anything bigger than a Sportster or a stock Evo.
NeilFS
Exhaust System Topics
Nov 19, 2012 11:49 AM
redrott
Nov 17, 2012 10:48 PM
roundy
Mar 29, 2012 10:21 AM
cobra2411
Oct 19, 2011 05:04 AM
JosephGarcia
Nov 19, 2007 09:14 PM
