Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
1994 Dyna Low Rider Carb Issue
Old Apr 9, 2011 | 07:16 PM
Owl's Avatar
Owl
Default 1994 Dyna Low Rider Carb Issue
I have a 1994 Low Rider that I thought had major motor issues. The bike was stored for almost three years, and when I tried to crank it the carb was all gummed up. I blew out all the openings, installed a new carb kit and cranked it up and the bike seems to run fine so long as I'm giving it gas. However, when I let it idle, it stops running. Adjusting the idle seems to have no effect.
The only thing I can think of is that the diaphragm on the vacuum may be causing the problem. I did notice that my new kit did not include a new diaphragm.
Can anyone else think of what might be causing the bike not to idle?
Old May 2, 2011 | 10:39 PM
aussie dave's Avatar
aussie dave
Just went through the same thing with a 94 Evo I bought.
When you put the kit in the carby did you remove all jets and clean out all the fuel pasages?
I put a kit in mine and she started/ran, but would not idle, i removed the idle jet and found it to be gummed up and also the fuel passage to be tottaly blocked....I used a bristle from a wire brush to push through the passage..then carb cleaner and then compressed air.
It was full of gunk...put the carby back on...adjusted idle screw to 2 1/2 turns out and she idle real nice.
And yes! replace the piston and diaphrame rubber....
Good luck
Aussie Dave.
Old May 3, 2011 | 11:39 AM
Owl's Avatar
Owl
Good luck
Aussie Dave.
Thanks for your help!
pfffool
EVO
24
Apr 13, 2023 08:47 PM
ilias
Sep 5, 2022 09:14 PM
lmz5150
EVO
29
May 12, 2017 02:41 PM
bdeuce
Sep 5, 2008 10:15 PM
redrum
May 31, 2008 12:19 AM
