Running rough when cold
97 Low Rider carb a little over 24,000 on the odometer.
Bike just recently started running really rough until well warmed up. Once its warmed up it runs like a top. Any suggestions?
I would pull the carby off, replace the carb to manifold rubber, re-set the float level, spray carby cleaner through all the passages and then check its got a 45 or 48 idle jet in.
That should fix it.
That should fix it.
Sounds like it's due for a carb cleaning. Pull it off, tear it apart, clean it up. As posted, set the float level, re-install, adjust the idle mixture (you have removed the EPA cap, right?), set the idle speed, and ride.
EPA cap covers the idle adjustment screw and it sits at the 6 o'clock position under the carby throat.
If you are not very mechanically minded I would avoid the head to manifold seals at this point as they are bit of a mission if you don't fully understand the job.
If you don't have the factory service manual, I would highly suggest you get one. There is a very good section on the carb, which explains how it works, and how to R&R it.
Removing that EPA cap involves gently drilling a hole through it and winkling it out with a small screw-driver. It is quite thin and doesn't need a hammer-drill, so take care! Underneath it is a brass slotted adjusting screw.
