Running rough when cold
Old Jul 15, 2013 | 08:45 AM
MJHJEA's Avatar
MJHJEA
I bought my first evo this year with 10k original miles, and it's been like yours from day one. Some days worse/better than others. Options are patience or go back to twinkieland…I chose patience. Still not convinced yet that I need carb work? Differing opinions on here when I too asked.
Old Jul 15, 2013 | 08:49 AM
MJHJEA's Avatar
MJHJEA
And what Murp said. I'm not so quick to close the choke when I take off. Sometimes pull it back out slightly til she cooperates.
Old Jul 15, 2013 | 05:26 PM
pfffool's Avatar
pfffool
That's why I am considering this a problem. For over a year I'd start up with full choke let it idle while I had a smoke push to half choke and go, no problem. Now it's running really rough for at least a mile down the road using the same procedure.
Old Jul 16, 2013 | 10:36 AM
MJHJEA's Avatar
MJHJEA
If you decide to do work on the carb, please give us an update on what transpires. I would be curious to know. I'm living with mine the way it is.
Old Jul 16, 2013 | 04:02 PM
Spanners39's Avatar
Spanners39
You replaced the plugs recently?....Evo's are funny about plugs....Iridium NGK's work best in my experience.
Old Jul 17, 2013 | 06:40 AM
MJHJEA's Avatar
MJHJEA
If plugs are in need of replacement, wouldn't bike run rough even after warmed up?
Old Jul 17, 2013 | 04:37 PM
Spanners39's Avatar
Spanners39
Not always, the motor can deal with issues better when its warm (ever heated up the plug on a 2-stroke lawnmower to get it to start?)
Any Evo that comes to me with starting or misfire probs gets new plugs before any diagnostics take place.....cures at least 25% of them straight away. Iridiums will last for ever but any fouling or wear on a non-iridium plug can cause a heap of problems.
Yesterday I did a home visit to a sick 1987 Softie......running on one cylinder....new plugs and it was fixed :-) Then I re-adjusted the S&S carby so it didn't foul the plugs at idle and the customer was 75 bucks poorer (inc labour) but 100% happier....wish it always was that simple!
BTW you can't always clean a fouled plug sufficiently for an Evo to run well on it, so new is always the better option, then cure the fault that makes them foul in the first place.
pfffool's Avatar
pfffool
when I fired the bike up today. choke out all the way fired right up but sounded like one cylinder severely miss firing. When I increased throttle the miss would even out. after a couple min. pushed choke all the way in idled okay still didn't sound quite right. Let it idle for 5-10 min. then went for a ride, still ran really rough for about a mile including backfiring when I opened the throttle.
Old Jul 17, 2013 | 04:40 PM
Spanners39's Avatar
Spanners39
Dodgy plugs or air leak would be my first thoughts on that one.
Old Jul 17, 2013 | 04:41 PM
pfffool's Avatar
pfffool
Also plugs and air filter were replaced after this first started. The problem seems to be getting worse. I did pull the plugs the other day and there was black carbon on the plugs, so I cleaned them off also pulled the air cleaner and sprayed carb cleaner in tto the carb. Did'nt seem to make a difference.
