Okay so I have a TC88B - w/95" BBK - Ported Heads - Large Valves - Big Cams - From DUNN PERFORMANCE in CO. - yada-yada-yada - I DIG the build....
Anyways I got the a NEW Mikuni HSR45 off eBAY - Right away I notice the Fuel Bowl screws are loose so the wrench monkey that I am decides to investigate and to my NOT so surprised eyes I see that the Float Needle Valve Assembly is missing. Ok fine so I go online and start searching for one. To my surprised eyes I find 4 options. Here is where I need your help guys. All you FI guys stay home!
I see Mikuni offers 4 options in sizes (2.3/3.5/4.2/4.5)
Which one do I get?!?!
Here is a list of the Jets I have...
MAIN (170/175/180) 175 installed
Pilot (not sure what size it is)
4.2 is standard/stock size for the HSR 45. That carb maybe a little on the large size for your combo, unless you're running a lot of compression, cam and have some major port work done.
Thanks - Yes I do have a Large cam and major port work done but the Compression is low 9.8:1 - I'll see how it goes - thanks for the input!
