Classic All 'historic' bikes.
Rear brake line removal
Old Mar 17, 2022 | 07:11 PM
76HDflh's Avatar
76HDflh
Default Rear brake line removal
Rebuilding the brakes on my 1976 FLH, have a question about the rear brake line. Has the original hose with a worn spot like something was rubbing on it for quite a while. I found 3 clips that position the hose along the swing arm, 2 on the arm and 1 under the transmission. the one under the trans is the problem, is there a simple sheet metal screw holding it in place and does it screw from the bottom up or is it held in place by the 9/16" bolt on the top. Scrubbing away a lot of grim and getting old don't have the flexibility to get see everything with out mirrors. There is also a junction where master cylinder meets rear line, can that be dropped from the engine or frame without removing the motor. Tough to get a line wrench on the fitting, tight to the motor. Thank you
Old Mar 19, 2022 | 10:23 AM
johnjzjz's Avatar
johnjzjz
Picture up what your seeing
Old Mar 20, 2022 | 11:58 AM
76HDflh's Avatar
76HDflh
Hello John, did some searching of the parts book, believe it was page 115 shows the Tee junction held in place with a bolt/nut combo. Looks like only one bolt. Only thing I noticed is book shows nut down, my bike has the bolt head down. Hopefully once removed I will gain the clearance for on in-line wrench.
Old Mar 21, 2022 | 07:49 PM
johnjzjz's Avatar
johnjzjz
Someone worked over the one line fitting - you will need a split box line wrench 6 point in 3/8 inch size
hell hound
Ironhead
Sep 27, 2017 04:40 PM
Rusty Axle
Shovelhead
Jan 7, 2017 06:39 AM
texashillcountry
EVO
32
Mar 25, 2016 04:39 PM
Drbukk06
Apr 11, 2014 04:38 PM
snacks63
May 21, 2010 10:07 PM
