Classic All 'historic' bikes.
55 Panhead
Old Nov 28, 2009 | 09:01 PM
rbrapp1's Avatar
rbrapp1
Default 55 Panhead Idle Problems
I have a 55pan that will not idle down after it is warmed up. I have since done a top end, new points, adjusted push rods twice, changed carbs and changed jetting. I noticed the front spark plug is darker than the back. Would worn rings maybe cause it to idle up after warm? Any ideas? Why?
Compression: Cold 90 front, 65 rear
Hot 85 front, 75 rear. More than 10% diff.
Thanks,
Russ
Old Nov 29, 2009 | 11:47 AM
FilthyLucre's Avatar
FilthyLucre
Check the condition of the manifold o-rings. A new top end should have better compression than that on the rear. You might want to check to see if you staggered the gaps in the rings properly.
Old Nov 29, 2009 | 12:28 PM
rbrapp1's Avatar
rbrapp1
Default 55pan
Changed o-rings and all looks good. Debating whether to take off jugs to check rings.
Thanks,
Russ
Old Dec 2, 2009 | 05:55 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If it is Linkert-equipped, they get worn around the throttle shaft area and will pull air.
Another thing to look at would be the distributor.
Broken spring, or the flyweights could be buggered.
Scott
kia
Aug 4, 2012 10:13 AM
rbrapp1
Panhead
Dec 4, 2009 11:34 AM
Mississippi Bagger
Mar 28, 2008 10:01 PM
jdusty21
Ironhead
Oct 11, 2007 04:55 PM
Z
May 14, 2006 07:59 PM
