Classic All 'historic' bikes.
Shovel head primary
Old Jul 6, 2005 | 01:10 PM
Coaler's Avatar
Coaler
Stage II
Default Shovel head primary
I have a 1978 FLH, a friend of mine talked me into isolating the primary from the motor oil so the primary oil is not circulating through the engine. But now there is pressure in the primary coming from somewhere and I can't keep the primary cover sealed well enough to keep it from leaking. Any ideas on how to fix.
Old Jul 6, 2005 | 09:03 PM
pococj's Avatar
pococj
Default RE: Shovel head primary
Might be coming through the main bearing behind the motor sprocket. When I closed off my '78 FLH I vented it through the top hose connection.
Old Jul 9, 2005 | 10:31 AM
71 shovelhead's Avatar
71 shovelhead
As pococj said no matter what you have to vent it and did you disconnect the feed and return lines? I did mine several years ago and used the chain oiler line as a vent . I ran it up under the seat. the only issue i had is I had to change the clutch to a kevlar wet or dry and because of the synthetic gearcase oil I get some seepage through the primary gasket,not bad just annoying
rjgordon0
Jul 20, 2019 02:27 AM
84 FLTC
Shovelhead
13
May 10, 2013 07:30 AM
Nebraska Lou
Shovelhead
May 9, 2013 08:45 PM
SBM
Dec 13, 2008 08:38 AM
Coaler
Oil Archive (no new posts)
Jul 10, 2005 10:45 AM
