Primary oil
Old Jul 19, 2019 | 06:19 PM
rjgordon0's Avatar
rjgordon0
6th Gear
Default Primary oil
Hi, I'm doing a bit of work on a friends 1976 FLH 1200 Electra Glide & was wondering how much oil should go in the primary ?
Thanks in advance
bob
Old Jul 19, 2019 | 08:53 PM
chopper_man's Avatar
chopper_man
You sure it's a sealed primary? Stock would be using engine oil via the oil pump.
Old Jul 19, 2019 | 09:21 PM
harley roadking's Avatar
harley roadking
Default Primary
I and most guys i rode with disconnected the hose and capped the oil pump , we used the hose a vent and filled primary (held upright) just until the bottom primary chain was partially covered. The old primary covers had an access plate for primary chain tensioner.I didn't like having clutch fibers and possible metal from starter ring circulating into motor.
Old Jul 20, 2019 | 02:27 AM
rjgordon0's Avatar
rjgordon0
6th Gear
I will check the oil line feed feed pipes !! Thank you.
doc308
Shovelhead
Jul 7, 2017 06:12 PM
cajun1957a
Shovelhead
Jun 22, 2014 12:16 AM
Nebraska Lou
Shovelhead
May 9, 2013 08:45 PM
vetto
Shovelhead
Aug 13, 2008 02:00 PM
Coaler
Oil Archive (no new posts)
Jul 10, 2005 10:45 AM
