installing mini tach
Old Aug 25, 2017 | 08:50 AM
davic666's Avatar
davic666
Stage IV
Default installing mini tach
i ride a rigid frame chopper with an ultima 127 cu.in. engine. it has an ultima single fire programmable ignition. i want to install a mini tach that i have, it has 4 wires (red, green, black & white) leading from it. what do i hook these 4 wires to? thanx
Old Aug 30, 2017 | 09:13 PM
Bentley16fbs's Avatar
Bentley16fbs
Red is constant power, Green is tach signal, Black is ground, and white is for lights. the green you will need to tie in with the coil, do some digging on exactly where, to get the signal. red should be on a key on power source, black to a good ground, and white on the lighting circit or a switch
Matthew Ruess
May 23, 2019 12:54 PM
RandyS
May 21, 2018 05:42 AM
Gtoyankee
Electrical/Lighting/Alarm
Aug 23, 2014 07:56 AM
softail99custom
Sep 5, 2010 07:02 PM
exlnt01
May 29, 2007 12:53 AM
