I am building a 2008 pro street custom that has an Ultima drivetrain (RSD). I broke the transmission shift arm and had to pull the main/counter shafts. That issue resolved I reinstalled everything and made sure the inner and outer primary lined up great.
At any rate the drive belt wants to walk to the outside of the trans pulley. As I understand it this is standard since the pulley is tappered.
On my Ultima 6 speed there is a belt guard ring that goes on after the belt. Questions are:
Is this ring neccesary? (it wants to pop off the tranny pulley)
Can I get a replacement belt guard ring?
Are there any other options for a belt guard that do not "snap" on?
Can i just leave the darn thing off?
Cheers!
2008 Pro Street
100" Ultima
Ultima 6 Speed
BDL Primary
S&\\;S Super G
The rear pulley has the tracking ring on stockers.If the belt tracks off the trans pulley it sounds like there is an alignment issue brewing.If the belt is forced against a tracking ring it will not last long.Never heard of tapered pulleys.Good Luck
Personally, I'd never skip the ring. \\; The pulleys should NOT be tapered. \\; I agree with dog155, if it's riding on the ring, the belt will wear out fast.....that will generate an enormous amount of heat from the friction.
But what the hell do I know?
~Joe
