Chain Drive help needed!!!!!!!!
Old Jul 6, 2008 | 02:24 PM
DannyNucclz's Avatar
DannyNucclz
Default Chain Drive help needed!!!!!!!!
I have a 160 rear tire on my rigid sporty and I need to do I chain conversion, what do I need to measure and order to complete this?
&nbsp\\;
Thanks,
Danny
Old Jul 6, 2008 | 05:12 PM
traveler's Avatar
traveler
Default RE: Chain Drive help needed!!!!!!!!
Well, the easy way to do this, is to get a long chain, and the tools to shorten it.&nbsp\\;\\\\\\; Go with an O-Ring chain, as you don't have to oil it all the time.&nbsp\\;\\\\\\; The Rev-Tech chains are nickel plated and are warrantied for 20,000 miles....no need to oil.&nbsp\\;\\\\\\; Of course, you might have to replace the sprockets and chain earlier than you would if you oiled the heck out of it all the time, but I hate the mess that gets all over the rear wheel and the bike, so I will just oil mine rarely.[&:]
&nbsp\\;\\\\\\;
Of course, you will have to do some work with spacers to get the wheel all lined up correctly.
&nbsp\\;\\\\\\;
~Joe
&nbsp\\;\\\\\\;
Old Jul 6, 2008 | 05:44 PM
DannyNucclz
Thanks but what do I do as far as measuring for offset and getting new sprockets since I am going from belt to chain?
Old Jul 6, 2008 | 08:14 PM
traveler's Avatar
traveler
well, I would say mount the front sprocket, and make the rear wheel match it.&nbsp\\; The wheel is not centered in the frame, then you can either put a spacer behind the sprocket or a spacer behind the front sprocket.&nbsp\\; Since you only have so many threads for the front sprocket, you better try to make everything line up on it FIRST.
&nbsp\\;
The EASY way, is to stay with a belt.&nbsp\\; I have a belt on my Superglide and LOVE it.&nbsp\\; I went with a chain on my rigid becasue I wanted a sprotor in the back.
&nbsp\\;
Belt are superior to chain IMHO.&nbsp\\; Unless you are doing like I am doing, or going for an old school look, the only reason to stay chain, is if you have 13o+ foot pounds of torque, and need a Heavy Duty 530 chain.
&nbsp\\;
Tryin' to help you here, but don't know what else to tell you.
&nbsp\\;
STAY BELT IF AT ALL POSSIBLE.
&nbsp\\;
~Joe
&nbsp\\;
Old Jul 6, 2008 | 08:27 PM
lolife's Avatar
lolife
call zimmermans....................... . . . . .................. . . . . ..........................
JSR132
Shovelhead
Jul 31, 2008 07:49 PM
startin over
Exhaust System Topics
Jul 16, 2008 06:12 AM
XKROME
Jun 23, 2008 03:27 AM
thrillseeker
Jun 21, 2008 08:47 AM
jakdelux07
Jun 10, 2008 09:14 PM
