need some help with overheating
Old Sep 25, 2008 | 12:08 PM
JRK5892's Avatar
JRK5892
Default need some help with overheating
My brother is having trouble with his bike overheating. His bike is custom chopper with only a 2 qt. oil pan to it. The engine is Revtech 110 with a mikani 45 carb. After 20 miles of cruising the rear cyl turns off due to heat. We just changed the oil to Mobile 1 20/50 synthetic. This winter we are going to put on a oil cooler, but does anyone have any suggestions on another type or weight of oil that will keep the engine temperature down???? Someone once told me that if a take out the 20/50 and put synthetic 60 weight in I will solve the problem. Any suggestions??
any help would be AWESOME!!!!
Old Sep 25, 2008 | 04:28 PM
pittguy's Avatar
pittguy
Dont know if you will ever get the temps down with a 2 quarter,oil cooler or not unless its huge.Same with the type/brand oils you use.Go towards a larger oil tank.
Old Sep 25, 2008 | 06:21 PM
JRK5892's Avatar
JRK5892
cool... man i was scared of that!
Old Sep 25, 2008 | 06:27 PM
Bluesssman's Avatar
Bluesssman
No oil will lower your temperatures. A cooler will help, but I feel the two quart oil capacity is your problem. It would be very easy to build a larger oil bag and the engine will certainly be a lot happier.
Old Sep 25, 2008 | 07:28 PM
JRK5892's Avatar
JRK5892
you would think it would be easier... but it is all molded in... ALL Of it... i would have to run another oil bag and pump... will try a heavy duty cooler first to see what that does for us... thanks guys!!!
Old Sep 26, 2008 | 09:15 AM
quigley's Avatar
quigley
I use this on my custom and it works well on keeping the oil cool. Send me a e-mail if you dont want to go thru e-bay.
Milan
http://i260.photobucket.com/albums/i...Milan/fan5.jpg
http://cgi.ebay.com/ebaymotors/ws/eB...m=150296179566
Old Sep 26, 2008 | 09:56 AM
hotrod351's Avatar
hotrod351
sounds like the builder was building a, show only bike, you would think any builder would know how much oil it takes to cool a motor down.
Old Sep 26, 2008 | 09:58 AM
hotrod351's Avatar
hotrod351
also might want to make sure hes not running lean. if the custom in the pic is his then it would be a shame to have a great looking bike like that and not be able to ride it.
Old Sep 29, 2008 | 09:56 PM
07bobber's Avatar
07bobber
run the redline 60 weight and run the oil cooler.....
Old Oct 2, 2008 | 06:27 PM
lolife's Avatar
lolife
That would suck to have a bike that beautiful and not be able to ride it.................... . . . . . . . . . . . . . . . ..
