metallic ticking noise
Old Jul 4, 2006 | 07:24 PM
ohmatron32's Avatar
ohmatron32
1st Gear
Default metallic ticking noise
Hi,
I have a Dyna 1983 with evo engine.......recently heard a noisy metallic ticking noise, can not pin point where it is coming from, maybe the pushrods....but had those out gave them a bit of a service, but still the ticking noise is there.
Have you guys any ideas on what it could be???
Please help
Jo
Old Jul 4, 2006 | 07:54 PM
grunt's Avatar
grunt
Default RE: metallic ticking noise
'Ticking' noises are lifters many times. Did ya see if any are stuck down?
Old Jul 4, 2006 | 08:00 PM
ohmatron32's Avatar
ohmatron32
1st Gear
sorry for sounding dumb.....but whats a lifter?
im new to harley davidsons :0)
Old Jul 4, 2006 | 08:04 PM
ohmatron32's Avatar
ohmatron32
1st Gear
Doh....tappets
just found out.......jezzz i feel thick lol
will check them out
Old Jul 4, 2006 | 09:35 PM
grunt's Avatar
grunt
ORIGINAL: ohmatron32
Doh....tappets
will check them out
Folks call 'em by different names, no 'thickness' there. I have very weak ones (by design) in the Hendersons - they sound like sewing machines and nothing I can do about it (NO aftermarket for that at all and I have no idea how to make my own).
If everything else is tight (within clearances), they are usually the culprit. If it is not apparent, you can also have them tested for a weak spring. Fast compression will make the 'tick' like mine.
Old Jul 13, 2006 | 04:37 PM
Big Daddy K's Avatar
Big Daddy K
Do you hear the "Ticking" noise aroung the cylinders of the engine. If so could be anything from the crank to the piston. I had a piston rod snap, but just before it did, I too heard a ticking noise...then BOOM![sm=bomb.gif]
JONNIEROCK
Dec 30, 2013 06:35 PM
JackGib46
Jul 27, 2012 09:31 PM
SeniorChief56
Apr 8, 2012 07:28 AM
jjb
Jun 13, 2009 06:59 AM
djwhaley
May 22, 2008 05:39 PM
