4 Speed Transmission
Old Nov 29, 2009 | 03:02 PM
snyder5630's Avatar
snyder5630
Stage II
Default 4 Speed Transmission
I have a custom softail with a 4 speed transmission, the question I have is how do you adjust the shifter throw as I need to actuall lift my leg off of the peg in order to change gears.
Old Nov 30, 2009 | 06:10 AM
pjb's Avatar
pjb
usually the shifter lever is splined. pull it off and rotate it to the desired position and then adjust the linkage rod length.
Old Dec 13, 2009 | 10:36 PM
driverx8's Avatar
driverx8
1st Gear
I agree, although the rachet top or turtle top usually doesn't need messed with unless it's worn out. If your rod is at end of adjustment and you still need to reach just get a longer rod. Mine is a reach when wearing tennis shoes, but fine with boots. I had that problem, having to lift shift leg hard, when an old tranny needed a rebuild also. If your fighting it, something is wrong, pull it and fix or replace it. I've been through that.
Old Dec 14, 2009 | 08:23 AM
pjb's Avatar
pjb
the linkage is famous for getting worn and sloppy. you can get a new bushing for the shifter shaft.
Rnt77
Jun 17, 2013 07:18 PM
128auto
May 7, 2013 09:32 PM
Mr.Black
Jun 23, 2010 09:28 AM
#1rocketman
Mar 25, 2010 11:41 AM
wireman2511
Mar 25, 2006 06:57 PM
