im building a scooter for my pop from a whole lotta colecting of parts some how my bottom end that was shop built and was a 1989 evo with left handed theads on the pinion side, got a new model flywheel crank pin ect . my problem is now the crank pin is right handed threads and the cone cover doesnt fit . what else am i up against with the newer model flywheel on the pinion side? thanks if im in the wrong area please re- direct me. Pan
OK JUST TO PASS THE INFO ON AT THIS POINT OF MY BUILD ALL I WILL NEED TO MAKE THIS COMBINATION WORK IS THR RIGHT NUT!!!! OTHER THAN ME!!!PAN
well I guess the cone cover needs machine work to lower the bushing behind the nut. so off to the mill I go. they want to much money for a new cover. I love workin in our machine shop any how !!! Pan
Reason: addition to problems with a basket case looking for some help
